6 Pages<12345>»
BrianT267
#21 Posted : Monday, April 13, 2009 1:37:48 PM(UTC)
BrianT267
Originally Posted by: richappy Go to Quoted Post
What was the original problem, no water pressure? If so, you might have a pump motor running backwards!
Thanks for the reply. The original problem (and current) is the dishwasher fills up but the does not start the cycle it just shuts off.
So I followed the procedure in this thread to clean out the Chopper. I did not take the pump motor out, looks like the chopper only fits one way. I inspected the check valve and it looked ok so I put it back. Could the rubber be fatigued even tough it looks good?
any advice on what to check next would be appreciated.
#22 Posted : Tuesday, April 14, 2009 12:43:06 AM(UTC)
I would pull the dishwasher and check the main pump/motor. THis is a 115 volt motor you can power up with a "cheater" cord. If you have a meter you can check for missing power at various places.
BrianT267
#23 Posted : Tuesday, April 14, 2009 6:02:25 PM(UTC)
BrianT267
Thanks I will give that a try.
srhgobears
#24 Posted : Monday, June 29, 2009 12:08:18 PM(UTC)
srhgobears
Slightly off topic - I'm having a problem (apparently) with the sump-pump gasket - our dishwasher has been leaking from underneath. I had a Kitchenaid/Whirlpool repair guy come out and stated he was 100% confident that the sump pump gasket was the culprit but it would be $300 in labor to repair and only a $20 part.
It sounds like the whole dishwasher needs to be unhooked (unfortunately the electrical was hard-wired into the dishwasher by the previous owner of our house), and the whole sump pump removed. Before I do this I wanted to check with the experts here on the viability of a novice do-it-yourselfer going at it. Here's the part I think I need: WHIRLPOOL Gasket, Pump sump
Input would be great.
#25 Posted : Monday, June 29, 2009 7:46:18 PM(UTC)
You can find the complete instructions in the tech sheets.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDI01ILBL2 | AppliancePartsPros.com
chiefa
#26 Posted : Saturday, August 8, 2009 11:24:43 AM(UTC)
chiefa
Just looked at one of these today, when you put the chopper back in, make sure it engages the motor impeller, if not, it is worn out and you will have to get a new one.Also, the drain pump and main pump alternate on and off to back flush the screen: a check valve allows this.
The check valve is on the right side of the chopper, a black thing stuck in the housing.
Check valve P# 8268375; chopper assy. P# 8268383
How can I check to make sure the chopper is engaging the motor impeller? The chopper blade seems to turn quite easily. I am wondering if this is what is causing the reduced water pressure so that the top rack in not getting cleaned.
#27 Posted : Saturday, August 8, 2009 2:24:04 PM(UTC)
You have a busted chopper, just pull out and check.
chiefa
#28 Posted : Thursday, August 20, 2009 4:03:24 PM(UTC)
chiefa
I pulled the chopper assembly, compared to a new one and it does not appear to be broken in any way. It also does engage the impeller when it is in place. Should I be testing the motor next? If so, I am not sure how to do that. Can you help?
#29 Posted : Friday, August 21, 2009 1:00:52 AM(UTC)
You might have a clog going to the upper spray arm. You also may have a low water level, just dump an extra gallon in to see if it works
taylorwhirlpool
#30 Posted : Sunday, July 11, 2010 2:19:20 PM(UTC)
taylorwhirlpool
I followed this thread. I took out and cleaned chopper, still making a terrible noise when washing. Not sure what else might be the problem?
In fact the noise didn't change at all when cleaned chopper. I took botom cover off and it just sounds awful under the machine.
Thoughts?
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
6 Pages<12345>»
