it work good at the begining but when is time to spin it won't spin
Most likely the problem is a bad lid switch. - The part number for the lid switch is AP204378 Here are the break down diagrams for the Admiral washer Model LNC6764A71Gene.
but still, when i open the lid it will shut the machine off, is this still a bad switch
Did the motor run when it comes to spin?
Did it drain?
Provide as much information as possible.
yes it drain, the motor i'm pretty sure runs, because i looked underneath and the belt was running.
i also checked the lid switch with a screw driver, to see if it would make a click sound; and it does.
Remove the front panel and check the belt and the belt tension when the washer goes on spin.
Check the transmission pulley.
If there is nothing wrong then the transmission gone bad.
i did all that, and i checked the belt and it is running but the basket doesn't move.
In that case the transmission is bad. - The part number for the transmission is AP3500335 Gene.
yeah it looks like that it, cause motor is runnig and move the belt, but the basket is like frozed! well thanks you for your help i appreciated
