jaime
#1 Posted : Tuesday, January 15, 2008 8:19:56 AM(UTC)
jaime
it work good at the begining but when is time to spin it won't spin
#2 Posted : Tuesday, January 15, 2008 4:34:01 PM(UTC)
Most likely the problem is a bad lid switch.
- The part number for the lid switch is AP204378
Here are the break down diagrams for the Admiral washer Model LNC6764A71
jaime
#3 Posted : Tuesday, January 15, 2008 6:06:51 PM(UTC)
jaime
but still, when i open the lid it will shut the machine off, is this still a bad switch
#4 Posted : Wednesday, January 16, 2008 9:16:49 AM(UTC)
Did the motor run when it comes to spin?
Did it drain?
Provide as much information as possible.
jaime
#5 Posted : Wednesday, January 16, 2008 3:04:55 PM(UTC)
jaime
yes it drain, the motor i'm pretty sure runs, because i looked underneath and the belt was running.
jaime
#6 Posted : Wednesday, January 16, 2008 3:11:53 PM(UTC)
jaime
i also checked the lid switch with a screw driver, to see if it would make a click sound; and it does.
#7 Posted : Wednesday, January 16, 2008 3:13:45 PM(UTC)
Remove the front panel and check the belt and the belt tension when the washer goes on spin.
Check the transmission pulley.
If there is nothing wrong then the transmission gone bad.
jaime
#8 Posted : Wednesday, January 16, 2008 6:45:11 PM(UTC)
jaime
i did all that, and i checked the belt and it is running but the basket doesn't move.
#9 Posted : Wednesday, January 16, 2008 7:12:06 PM(UTC)
In that case the transmission is bad.
- The part number for the transmission is AP3500335
jaime
#10 Posted : Thursday, January 17, 2008 4:11:23 AM(UTC)
jaime
yeah it looks like that it, cause motor is runnig and move the belt, but the basket is like frozed! well thanks you for your help i appreciated
Guest (6)
