2 Pages12>
double door thermador
#1 Posted : Tuesday, January 15, 2008 2:54:40 PM(UTC)
Upper oven will not heat - Bake or Broil. Lower oven works fine.
#2 Posted : Wednesday, January 16, 2008 12:01:42 PM(UTC)
Most likely the hi temperature cut out is "off". It is resettable and located on the back of the oven.
#3 Posted : Wednesday, January 16, 2008 12:12:25 PM(UTC)
Gene,
Thank you for your reply and suggestion. I will remove the oven from the wall and reset the "hi temp cut off" on the back of the oven. Hopefully it is easily identifiable. I will let you know what heppens. Thanks!
#4 Posted : Sunday, January 20, 2008 8:52:35 AM(UTC)
I have removed the oven from the wall. I cannot locate a hi temperature cut out to reset. The only wires/items on the back of the oven are the wiring and connection points to the heat elements, the interior oven lights and the interior oven thermostats.
I did check the voltage coming to the elements and found the red wire for the broiler element and the black wire for the bake element both of which are connected tot he left side of the selector switch do produce 120 volts. Whereas the Blue wire that jumps to the bake and broil element that is connectected to the right side of the selector switch only produces about 60 volts. My understanding is that both leads should produce 120 volts.
I also noticed that when the selector switch is on Bake, both the red lead to the broil element and the black lead to the bake element produce 120 volts. Whereas when the selector switch is on broil the red wire connected to the broil element produces 120 volts and the black wire connecting to the bake element produces 14-15 volts. I assume this is normal in that when baking, the broil element may come on for a short period of time in order to quickly pre heat the oven to the disired bake temperature.
Please Advise.
kawfeeman
#5 Posted : Sunday, January 20, 2008 9:02:16 AM(UTC)
kawfeeman
take both leads off of the bake element... ( MAKE SURE YOU DO NOT ALLOW EITHER OF THEM TO TOUCH CHASSIS !!!) CHECK each wire to ground to see which is HOT ( or has 120vac .. ) then turn power off and the wire that is not HOT ( doesn't have 120vac ) follow back to point of origin ( could be to a non-resettable safety t-stat, but could also be to the push button switch , which by the way, i think is NLA ) but it could also be to the HOT WIRE RELAY ....
#6 Posted : Sunday, January 20, 2008 9:38:00 AM(UTC)
Kawfeeman,
I have done as suggested. The hot wire, or the wire that does not produce 120 volts, rather 48-60 volts, connects directly to the selector switch at the front of the oven. (along with about 30 other wires) part number 14-19-19-198. I do not see a reset button or switch on that part.
kawfeeman
#7 Posted : Sunday, January 20, 2008 9:46:15 AM(UTC)
kawfeeman
there is not a reset for the selector switch .. ( the other wire definitely does have 120vac ) ?
#8 Posted : Sunday, January 20, 2008 9:52:07 AM(UTC)
No reset for the selecor switch that I can see. The other lead definately has 120 volts. In fact, the 120 volt producing lead comes form the other side of the selector switch.
kawfeeman
#9 Posted : Sunday, January 20, 2008 11:18:42 AM(UTC)
kawfeeman
have you made certain that the wire is not bad ???
#10 Posted : Sunday, January 20, 2008 11:33:02 AM(UTC)
Yes, I can test the voltage/source at the selector switch, eliminating the wire question.
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
2 Pages12>
