muleyhunter
#1 Posted : Sunday, August 16, 2009 1:44:35 PM(UTC)
muleyhunter
When starting washer the water comes on but just keeps draining out and won't fill. Any suggestions will be very appreciated.
sidfink43
#2 Posted : Monday, August 17, 2009 3:48:56 PM(UTC)
sidfink43
A siphon is beingcreated in your drainage tubes. There is nothing which stops water from coming out of your machine, the only thing that prevents this is that the discharge hose outlet is higher than the water level in the tub.
In your case either the discharge hose is lower, or you have somehow sealed off where the discharge hose enters the discharge pipe (a lot of times this happens because someone taped the hose in to keep it from flipping out)
Anyway, fix one of these situations and your problem will go away.
timeormoney
#3 Posted : Monday, August 17, 2009 7:48:24 PM(UTC)
timeormoney
Thank you sooooooooo much for this help, testing it on my Roper washing machine right now. The drain pipe was extended far down into the drain hole. It is weird that this is the first time in 3 years, but I can now hear it running so thanks again!
muleyhunter
#4 Posted : Tuesday, August 18, 2009 4:19:06 PM(UTC)
muleyhunter
That was the problem :):):):)
sidfink43
#5 Posted : Tuesday, August 18, 2009 4:22:09 PM(UTC)
sidfink43
Thanks for updating us, glad it worked out for everyone.
A Couple of Problems, Dryer won't Heat / Washer won't fill with water (Washer Repair)
by gregjbutler 2/11/2013 4:14:21 PM(UTC)
washer won't fill with water. (Washer Repair)
by mikeshawver 4/21/2012 9:51:25 AM(UTC)
by Brandonks 3/8/2012 5:39:24 PM(UTC)
by colleenrclark 10/16/2011 4:20:46 PM(UTC)
GE Washer won't fill with water (Washer Repair)
by Nikon23 10/13/2011 7:40:41 PM(UTC)
frigidaire front load washer won't fill with water (Washer Repair)
by tponcsak69 8/14/2011 9:29:38 AM(UTC)
by elrodjo 8/6/2010 3:58:05 PM(UTC)
Haier Washer won't fill with water (Washer Repair)
by bealcli 7/9/2009 11:19:49 AM(UTC)
Dishwasher won't fill with water (Dishwasher Repair)
by Tru2Chevy 6/26/2009 7:41:16 PM(UTC)
by peco 5/27/2009 8:37:59 AM(UTC)
woman in need of help washer won't fill with water (Washer Repair)
by lindavanzandt 11/30/2008 11:20:23 AM(UTC)
Whirlpool washer won't fill with water (Washer Repair)
by Evonne 10/22/2008 12:52:24 PM(UTC)
by gimpy54 7/1/2008 10:25:11 AM(UTC)
dishwasher won't fill with water (Dishwasher Repair)
by jhmorlang 2/6/2008 8:48:21 AM(UTC)
