The lower spray arm appears to be clogged. Should I replace it or try to take it off and clean it out? How do I get it loose. Are there any other pieces connected with it that should be replaced or cleaned
Great advice Gene, but we should also mention that the spray holes on all maytag dishwashers are very tiny and plug up very easily. If the bottom ones plugged, chances are the other one or two will be plugged also. So just goes to show you RINSE RINSE RINSE those dishes and everyone could save themeselves many dishwasher headaches.:D
