BeckyNTulsa
#1 Posted : Monday, January 14, 2008 9:48:33 AM(UTC)
BeckyNTulsa
The lower spray arm appears to be clogged. Should I replace it or try to take it off and clean it out? How do I get it loose. Are there any other pieces connected with it that should be replaced or cleaned
#2 Posted : Monday, January 14, 2008 6:15:42 PM(UTC)
Hi Becky,
To remove the lower spray arm you have to unscrew the spray arm cap (#34 on the pump & motor break down diagram) first.
I would recommend to replace it instead of cleaning because it's not expensive part.
Also I would recommend to remove the pump cover (#4 on the pump & motor break down diagram) and check the pump housing filter (#6 on the pump & motor break down diagram) and the rinse arm assembly (#7 on the pump & motor break down diagram).
If they are clogged, it's better to replace them too.
- The part number for the lower spray arm is AP178746
- The part number for the pump housing filter is AP2644606
- The part number for the rinse arm assembly is AP403589
Here are the break down diagrams for the Maytag dishwasher Model MDB4040AWB
Good luck.
ripleys
#3 Posted : Monday, January 14, 2008 6:26:23 PM(UTC)
ripleys
Great advice Gene, but we should also mention that the spray holes on all maytag dishwashers are very tiny and plug up very easily. If the bottom ones plugged, chances are the other one or two will be plugged also.
So just goes to show you RINSE RINSE RINSE those dishes and everyone could save themeselves many dishwasher headaches.:D
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
by Guest 10/20/2022 10:23:08 AM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Maytag dishwasher, cancel button (Dishwasher Repair)
by jtt21 6/28/2022 5:24:58 PM(UTC)
Maytag dishwasher quiet series 300 (Dishwasher Repair)
by Guest 6/12/2022 7:04:36 PM(UTC)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 5/16/2022 9:37:56 AM(UTC)
Maytag dishwasher MDB4709AWW1 (Dishwasher Repair)
by dkmc1953 3/6/2022 1:13:12 PM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Maytag Dishwasher Making Clanging Noise Even When Empty (Dishwasher Repair)
by gtg931 12/20/2021 7:13:20 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
Maytag dishwasher MDB4949SDZ0 (Dishwasher Repair)
by tonygm 5/29/2021 1:47:18 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Maytag dishwasher fills, then drains (Dishwasher Repair)
by vtfireman85 3/12/2019 7:30:34 PM(UTC)
