snellulite
#1 Posted : Tuesday, August 11, 2009 12:54:14 PM(UTC)
snellulite
i've got a washing machine that on fri. i was on the way out of town and needed on more load washed. of course the machine got to the rinse cycle and stopped. it wouldn't run, rinse or drain. also my wife said she smelled somthing like hot or burrning wires. i was in a hurry so i left it for the weekend when i got back on mon. the machine was empty of water but the socks were smelly so i tried to run a smell load...it worked but didn't like it. not sure where to go from here can you help??? i bought the machine used and am not sure of the age 4-7yrs. old
magician59
#2 Posted : Tuesday, August 11, 2009 7:08:54 PM(UTC)
magician59
First thing to check is the lid switch. It may be just on the verge of total failure. Open the lid and depress the switch activator with a small screwdriver or similar tool. It should respond with a well defined click. If it feels spongy, replace it.
snellulite
#3 Posted : Thursday, August 13, 2009 7:33:54 AM(UTC)
snellulite
lid switch checks out. definate click. any other ideas? thanks, snellulite
magician59
#4 Posted : Friday, August 14, 2009 3:51:40 AM(UTC)
magician59
Open up the console and look to see if there is any obvious burnt wiring or connectors. If there is a circuit boare, look for burnt or discolored components on the board.
Guest (5)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
Frigidaire fill tube leak: Is it just a bad design? (Refrigerator & Freezer Repair)
by bobhucker 6/18/2024 7:59:46 AM(UTC)
Frigidaire FGHT2055VF - light switch? (Refrigerator & Freezer Repair)
by ranger58 6/13/2024 11:14:06 AM(UTC)
Drain pump working intermittently(?) (Dishwasher Repair)
by GRobLewis 6/8/2024 4:45:45 PM(UTC)
: How Do You De-Stress After a Long Day? (General Talk)
by Guest 6/6/2024 11:03:36 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
GE XL44 oven woes: temp knob fell out, how to remove cover? (Oven Repair (including Ranges and Cooktops))
by cyberdingo 4/29/2024 8:32:15 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
OEM or Aftermarket Replacement Bake Element? (Oven Repair (including Ranges and Cooktops))
by lbb78 4/18/2024 10:05:55 AM(UTC)
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
How does Whirlpool agitate? (Washer Repair)
by Alex Pabloroux 4/12/2024 1:40:40 PM(UTC)
replacement for discontinued GE convection fan motor? (Oven Repair (including Ranges and Cooktops))
by evofxdwg 4/11/2024 11:12:12 AM(UTC)
