richard72
#1 Posted : Sunday, August 9, 2009 2:39:34 PM(UTC)
richard72
a lot of water on floor under refrigerator. I removed the front kick plate and found the entire condenser covered with dog hair. It was very thick. I vac. this off. In freezer compartment I removed the back wall plate and poured water in the drain pan, to see if the drain was ok...and it was. The weather has been very humind here lately. Do you suppose that the blocked condenser for air flow could have been the problem? Freezer and refrigerator controls are set at the recommended setpoint (on #3). Richard L
#2 Posted : Monday, August 10, 2009 2:35:47 PM(UTC)
I would not do anything at this time and watch it for a few days after cleaning.
richard72
#3 Posted : Tuesday, August 18, 2009 5:30:29 AM(UTC)
richard72
Found the problem for the water on the floor, there was pin holes in the 1/4" copper supply water line to fridge, that was inside the cabinet next to it. I will replace that line with the plastic/nylon line asap. thanks anyways. Richard
#4 Posted : Wednesday, August 19, 2009 11:06:18 PM(UTC)
Richard,
I'm glad you were able to find it. Good luck with your refrigerator.
Kenmore Refrigerator Pooling Water on Floor (Refrigerator & Freezer Repair)
by vintess 2/17/2017 5:18:47 PM(UTC)
Refrigerator water on floor (Refrigerator & Freezer Repair)
by kruegerbest 6/1/2015 10:13:31 AM(UTC)
Water on floor (Refrigerator & Freezer Repair)
by bstreyle2 1/19/2015 5:35:06 PM(UTC)
whirlpool cabrio displays ul code and spills water on floor (Washer Repair)
by dirtman 13 7/29/2012 8:06:36 PM(UTC)
Ice in bottom of my LG freezer & water on floor (Refrigerator & Freezer Repair)
by dutchreagan 4/5/2012 6:46:53 AM(UTC)
Refridgerator leaking water on floor (Refrigerator & Freezer Repair)
by greg2012 8/27/2011 6:54:45 AM(UTC)
Refrigerator - Water on Floor, Repairing a Clogged Defrost Drain (Refrigerator & Freezer Repair)
by mousavi2011 3/25/2011 10:25:25 AM(UTC)
Bosch Dishwasher, Water on Floor (Dishwasher Repair)
by gourso 2/15/2011 9:08:30 AM(UTC)
by wvogel57 11/19/2010 8:49:10 AM(UTC)
Kitchenaid leaking water on floor (Refrigerator & Freezer Repair)
by mjslord 7/30/2010 8:10:10 AM(UTC)
Defrost water on floor (Refrigerator & Freezer Repair)
by sushil 4/25/2010 7:02:11 AM(UTC)
Freezer ice buildup and water on floor (Refrigerator & Freezer Repair)
by Kat Stahl 4/3/2010 8:49:48 PM(UTC)
Balance Ring hitting Ring Tub and water on floor (Washer Repair)
by mrwto 1/26/2010 1:34:37 PM(UTC)
Water on floor/clicking noise in rear (Refrigerator & Freezer Repair)
by eorcdave 8/22/2009 10:10:34 AM(UTC)
Water on floor in front of refrigerator. (Refrigerator & Freezer Repair)
by joeblue 8/19/2009 7:07:50 AM(UTC)
