dsanford11
#1 Posted : Thursday, August 6, 2009 11:42:30 AM(UTC)
dsanford11
First time poster here, so thanks in advance for any wisdom you can share that will point me in the right direction. This fridge just quit while I was at work one day. Came home and there was a considerable amount of water on the floor. Thinking it was the defrost terminator again, I picked one up and replaced it. No help. So I checked further. Compressor not running at all, but condensor fan running fine. I had a spare defrost timer and installed it, no help still. There is power to the overload relay on the compressor, but nothing at the PTC relay. Not knowing exactly how to check, I replaced the PTC, no help still. I by-passed the cold control also,and checked continuity on the ground circuit.Still nothing. There is good voltage to the evaporator motor, but it doesn't run. I threw a new one in just in case. Still power there but won't run. I checked the defrost element and the door switches. They all checked out fine. What am I missing here? Does power go into the compressor thru the overload and out to the PTC relay? That would explain a no power situation and point to a bad compressor. If it is vice versa, there has to be somewhere I am not looking. How would I check the compressor at the 3 exterior contact points to see if it is truly bad? Thanks, JR.
magician59
#2 Posted : Thursday, August 6, 2009 12:32:18 PM(UTC)
magician59
Remove the PTC and overload from the compressor. Take OHM readings from the connector pins and report them. See if there is any continuity from any of the pins to ground. If there is, the compressor is bad and needs to be replaced.
dsanford11
#3 Posted : Thursday, August 6, 2009 3:52:57 PM(UTC)
dsanford11
Well bad news for me, it appears that there is continuity from all three pins to ground. That was a simple to do test I should have done before, but was too hardheaded to ask for help. I appreciate the quick reply and for sharing your knowledge a bit. Thanks, JR.
