2 Pages12>
hulaboy
#1 Posted : Wednesday, January 9, 2008 7:57:29 PM(UTC)
hulaboy
electric oven not heating, there is no fault code, display panel works fine. could it be the temp sensor if so how would I test it.
thanks for the help.
#2 Posted : Thursday, January 10, 2008 3:59:10 PM(UTC)
What shows on the display when the bake is "on"?
I need the complete model number of the unit.
hulaboy
#3 Posted : Friday, January 11, 2008 8:39:00 AM(UTC)
hulaboy
Hi Gene.The complete model # is PGLEF385CB3 . The display seems to be working normal.When bake is turned on it does not preheat as usual and instead shows the temp programmed. Thanks very much for your help.
Hulaboy
#4 Posted : Friday, January 11, 2008 10:28:31 AM(UTC)
Hi Hulaboy,
What about all other functions: broil, convection and surface burners?
Did they work or something else is wrong?
hulaboy
#5 Posted : Friday, January 11, 2008 4:09:55 PM(UTC)
hulaboy
The oven does not heat on any of the cycles ( broil , bake ,convection broil , convection bake or clean). The display is working fine.When bake is started the display shows the programmed temp, no preheat.The suface burners work fine.Thanks hulaboy
#6 Posted : Tuesday, January 15, 2008 12:25:44 PM(UTC)
Pull the range off the wall, remove the back cover and locate the common wire for the bake and the broil heating elements.
Remove this wire from the heating elements terminals and check for 120V between this wire and the ground when the control calls for heat.
If there is no 120V, then the control board has to be replaced.
Unfortunately the part is no longer available.
hulaboy
#7 Posted : Tuesday, January 15, 2008 4:30:34 PM(UTC)
hulaboy
Hello Gene
I located the common wire between the broil and bake elements, disconnected the wire from the bake element, with control set to bake I checked the voltage between the disconnected common bake wire and the main black ground terminal, there was no voltage. Same thing on the broil cycle. Does this mean the control panel is bad? When you say the part is not available does this mean I couldn't order it from Frigidaire?
Thanks alot.
Hulaboy.
#8 Posted : Tuesday, January 15, 2008 5:08:34 PM(UTC)
No doubt the problem is a bad control board.
No longer available part means the manufacturer has been discontinued to make this part.
The only chance is if you or someone else can fix the old control board.
hulaboy
#9 Posted : Wednesday, January 16, 2008 2:30:07 PM(UTC)
hulaboy
I'll contact a local repair company to see if they can repair the control board. Thanks for all your help Gene.
Hulaboy.
hulaboy
#10 Posted : Thursday, January 17, 2008 8:54:58 AM(UTC)
hulaboy
Hello Gene
I was able to get a new control board , part #318193201,cost $270. Is it difficult to install? Is there anything I need to know before I begin?
Thanks.
Hulaboy.
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
2 Pages12>
