resloan
#1 Posted : Saturday, August 1, 2009 12:45:41 PM(UTC)
resloan
Everything works except the heat. Got a VOM. Where do I start and are there any disassembly instructions online?
applianceman
#2 Posted : Sunday, August 2, 2009 6:48:09 AM(UTC)
applianceman
On this dryer the back is removed to access the heating components. Disconnect power from dryer then remove the back. Once removed you should see the heater can on the right-hand side. On that heater can you should see two thermostats and at the bottom you should see the terminals for the heater. Remove the wires from the two thermostats and the heater. Check for continuity across each thermostat and the heater. If either of the two thermostats is open replace both (they come together in a kit). If the heater is open replace the heater. More than likely one of these three parts is the cause of your problem but if not post back and we will go from there. Note that after the repairs are done check the vent because if the vent is clogged it can cause these parts to go bad along with other problems. Clothes Dryer Repair Guide
resloan
#3 Posted : Sunday, August 2, 2009 1:03:43 PM(UTC)
resloan
On the bottom of the heater can are 3 terminals. Two lower terminals and one upper. The lower left terminal has no wire to it, but apparently gets juice through a thermostat connected to the top terminal. Anyway, I pulled the element cover and one section is very black and the coil is burnt into. I checked both thermostats and they have continuity.
I'm wondering why the element burnt up. Its an expensive part, and should have been protected by the thermal cutout?? I also checked the thermal fuse and cycling thermostat which were OK.
applianceman
#4 Posted : Sunday, August 2, 2009 5:02:52 PM(UTC)
applianceman
At times heating elements will just burn out. The thermostats (thermo cutout) are not to protect the element they are for safety to protect against fire.
A clogged vent can reduce the life of the heating element so check that. I also recommend cleaning out the vent once a year.
resloan
#5 Posted : Sunday, August 2, 2009 5:19:18 PM(UTC)
resloan
OK. Thanks. BTW, how is the vent accessed?
applianceman
#6 Posted : Monday, August 3, 2009 5:28:58 AM(UTC)
applianceman
Well I am mostly talking about the vent from the dryer to the outside.
resloan
#7 Posted : Monday, August 3, 2009 10:17:06 AM(UTC)
resloan
I'm referring to the chamber inside the dryer that leads to the vent. Its on the left side. Can it be opened up and cleaned? Or is this necessary? (I have never used this dryer, it came with a used washer I bought and the owner said it needed a heat element.) The external venting is clean.
applianceman
#8 Posted : Monday, August 3, 2009 6:21:42 PM(UTC)
applianceman
Normally it is not necessary to clean the eternal vent unless when you turn it on you get no airflow. But to access the vent you must remove the tub this page may help Whirlpool Clothes Dryer Disassembly Guide
applianceman
#9 Posted : Monday, August 3, 2009 6:24:48 PM(UTC)
applianceman
[FONT='Times New Roman']Since the dryer is second hand you should at least remove the front and clean the blower out. but I may not even worry about that if you get good airflow. [/FONT]
Guest (6)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
