leslie_0809
#1 Posted : Friday, July 31, 2009 4:44:14 PM(UTC)
leslie_0809
timer comes on but dryer won't run. replaced the thermostats but that didn't work. when dryer did come on it ran a few minutes, got warm and stopped and now will not come on at all. flipped the breakers slowly, didn't work. do we need to replace the fuse or the whole motor?
sidfink43
#2 Posted : Sunday, August 2, 2009 6:25:32 AM(UTC)
sidfink43
Hi Leslie
Sorry for your difficulties. You need to have a test meter to diagnose the problems. First check with the meter to make sure you have 120 volts to each side of the connection block. Then check continuity of your thermal fuses and thermostats (I know you replaced them but check anyway). Finally, check the heating element.
If all of these check out, and they probably your problem can be in the start switch, timer or motor. From what you have described the motor is the likely candidate.
Good luck.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
