bmedlen
#1 Posted : Thursday, July 30, 2009 3:48:03 AM(UTC)
bmedlen
I need to replace the catch on the dryer door. Is there a special tool to remove the screws to take the door apart in order to replace the latch?
sidfink43
#2 Posted : Friday, July 31, 2009 3:26:49 PM(UTC)
sidfink43
I don't think so but take a look at the service manual which should tell you exactly how to do.
Don't have the service manual? Here it is
https://secured.whirlpoo...5435db/$FILE/8178584.pdf
Good luck
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
Whirlpool Cabrio WTW6300SW1 (Washer Repair)
by Fieldsafo 2/12/2024 4:00:47 PM(UTC)
Whirlpool Cabrio Drum Mounting Hub replacement options (Washer Repair)
by Guest 5/8/2023 6:48:34 AM(UTC)
Whirlpool Cabrio - passes diags but wont initiate a cycle (Washer Repair)
by Jack Jolly 2/13/2023 9:20:45 AM(UTC)
Whirlpool Cabrio electric dryer model WED5800BW0 (Dryer Repair)
by thorning 9/26/2022 12:44:56 PM(UTC)
Whirlpool Cabrio washer water pressure too high in detergent dispenser (Washer Repair)
by dwprog 8/10/2022 11:52:58 AM(UTC)
Whirlpool Cabrio washer TWT8600 will not spin at the end of cycle (Washer Repair)
by ADK522JNRS 6/1/2022 5:53:35 AM(UTC)
Whirlpool Cabrio WTW6600SW2 drum will not balance (Washer Repair)
by Guest 5/28/2022 7:45:19 AM(UTC)
Whirlpool Cabrio Washer Stops Intermittently (Dishwasher Repair)
by Amadago76 4/1/2022 9:57:02 AM(UTC)
Whirlpool Cabrio (WTW6800WW1) (Washer Repair)
by jkernsjr 1/13/2022 1:01:50 PM(UTC)
Whirlpool CabrioWTW5800BC0 (Dryer Repair)
by Juiceboi01 12/19/2021 8:09:03 PM(UTC)
Whirlpool Cabrio Washing Machine replaced transmission (Washer Repair)
by reggiebliss 8/26/2021 7:31:39 PM(UTC)
Whirlpool cabrio won't spin out (Washer Repair)
by Guest 7/28/2021 7:22:56 AM(UTC)
Whirlpool Cabrio Washer banging noise at the spin cycle (Washer Repair)
by Guest 5/13/2021 2:33:38 PM(UTC)
Whirlpool cabrio washer won’t final spin (Washer Repair)
by Guest 3/20/2021 8:31:43 PM(UTC)
