vmill63
#1 Posted : Wednesday, January 9, 2008 9:26:17 AM(UTC)
vmill63
Water accumulates in the bottom of refrigerator.
How do I fix it?
#2 Posted : Wednesday, January 9, 2008 7:02:35 PM(UTC)
Most likely the problem is the clogged and frozen drain behind the back panel in the freezer.
Remove the back panel, defrost the drain using a hair dryer and clean it using hot water.
If you need the break down diagrams, post the complete model number of the fridge.
Best regards.
vmill63
#3 Posted : Wednesday, January 9, 2008 7:49:22 PM(UTC)
vmill63
The model number is:
KTRS22MAWH10
arturogondaro
#4 Posted : Monday, March 2, 2009 10:28:40 AM(UTC)
arturogondaro
Best regards.
I have a Model # KSRD25FKWH03 KitchenAid Rerigerator. I have a sheet of ice that forms in the bottom of the freezer periodically. From what you said, to fix it I need to take off the panel in the INSIDE back of the freezer compartment. Once I do this, it will be obvious where the drain is that needs to be defrosted and cleaned out?? Is this correct???
Thanks,
Arturo
#5 Posted : Monday, March 2, 2009 1:44:25 PM(UTC)
Arturo,
The drain hole in your refrigerator is in the center of the drain pan under the evaporator coil behind the rear panel in the freezer.
arturogondaro
#6 Posted : Monday, March 2, 2009 2:31:05 PM(UTC)
arturogondaro
Gene,
I figured it out earlier this afternoon. Like most repairs, it takes more time to take the covering apart than it did to fix the drain. (Had to take the shelf supports off so that I could get the cover off so that I could see the drain.)
I used the hair dryer to melt all the ice in the pan and some of the ice in the actual drain hole. Then, I used a medicine dropper to drop very hot water into the drain hole until it finally cleared to drain. (At least there was some water in the pan underneath the refrigerator finally.)
I appreciate your getting back to me. Thanks for your tip.
Arturo
#7 Posted : Monday, March 2, 2009 3:41:27 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Guest (5)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Kitchenaid Refrigerator Issues With Dispensing Water (Refrigerator & Freezer Repair)
by Guest 10/2/2023 1:29:10 PM(UTC)
Kitchenaid Refrigerator Help Needed (Refrigerator & Freezer Repair)
by Guest 5/31/2022 3:40:02 PM(UTC)
KFIS29BBMS03 KitchenAid Refrigerator freezer only gets to 17 degrees, Fridge seems okay at 38 (Refrigerator & Freezer Repair)
by JCohen8008 6/28/2021 8:00:28 AM(UTC)
KSRS25IKBL03 KitchenAid Refrigerator stopped making ice - optics have been replaced (Refrigerator & Freezer Repair)
by Jfranks 12/5/2020 2:47:58 PM(UTC)
Kitchenaid refrigerator problems (Refrigerator & Freezer Repair)
by Kendug 8/12/2020 7:40:47 AM(UTC)
Help! Tech sheet lost for Kitchenaid refrigerator (Refrigerator & Freezer Repair)
by DANDKB 4/24/2020 11:38:19 PM(UTC)
Kitchenaid Refrigerator KSSSQTB00 (Refrigerator & Freezer Repair)
by Spearcatcher 12/18/2018 1:39:56 PM(UTC)
KitchenAid refrigerator ice chute replacement (Refrigerator & Freezer Repair)
by harrychou25 7/11/2018 1:44:23 AM(UTC)
kitchenaid refrigerator diagnostic mode (Refrigerator & Freezer Repair)
by oldfartsexpress 5/24/2018 5:29:43 PM(UTC)
Hinge repair on KitchenAid Refrigerator (KSSC42QTS00) (Refrigerator & Freezer Repair)
by clivedaw 1/5/2018 12:47:03 AM(UTC)
KitchenAid refrigerator did not work (Refrigerator & Freezer Repair)
by hhh123456 6/14/2017 1:58:45 AM(UTC)
Kitchenaid Refrigerator ice maker (Refrigerator & Freezer Repair)
by southerncooker7173 8/25/2016 11:01:00 AM(UTC)
KitchenAid refrigerator KSSC48QTS00 not dispensing water or producing ice (Refrigerator & Freezer Repair)
by Koolman10 6/25/2016 11:40:22 AM(UTC)
