Groups ready for retrieval: Senior Expert, Administrators Joined: 7/19/2007(UTC) Posts: 27,455
You can force the defrost cycle by bypassing wires at the main control board, but I personally do not like it. I would let it work and just monitor it. As you described in the first post, two weeks should be enough to see how it works.
Hi Gene, I have a Kenmore side by side refridgerator, 106.53606200. The problem happend this morning, the fridger is not cold enough. There is no problem with a freezer. There is no food blocking the air vent in both sides, but the cold air doesn't come out into fridger. Can you help me what to do?
Thanks in advance.
Check if the fan in the freezer works. If it does then replace the air diffuser (in the upper left corner in the fresh food compartment). - The air diffuser Part number: AP3084126
I have a GE TFX22KRDAWW a few weeks ago the fresh food side got warm. I opened the panel in the freezer section and it was a block of ice on the coils. Defrosted and also did a through cleaning of all dust around fridge. It has worked for several days and now same problem. Looking at the parts list I don't see a listing for a defrost timer for this fridge. There is a listing for a defrost heater assembly. I am thinking of going ahead and getting and replacing this. They also list a redsigned assembly, but not sure if that will fit or not. Any suggestions if I am going in the right direction.
Originally Posted by: Gene  I had already ordered the heater before your answer. I cannot believe it arrived the very next day. I have installed it and so far it seems to be working. If it freezes up again I will try the test on the timer, I did not realize it was in the fresh food section. Thanks for your response, this is a great website and great place to order parts. Local place said they could get me part in 7-10 days and would cost more money.
A bad defrost heaters is one of most common problems with GE refrigerators. I hope this repair solved the problem. Thank you for your good words and your feed back. Good luck with your refrigerator.
i have a side by side ge model gss25wgmbbb it doesn't dispanse water and no ice . please help
Thanks Gene for your excellent explanations. I was able to diagnose a problem with my defrost thermostat. You may want to mention that it is also called a Bimetl - def. It will take a week for my part to arrive.
Is it OK to run the fridge without the metal back panel in the freezer so I can easily run the defrost by bypassing the thermostat? It also seems like the refrigerator runs constantly without stopping - could this be related to leaving the back panel off?
I have a Kenmore KBRS22KFWH0 with the freezer on the bottom.
Originally Posted by: ackscott  Thanks Gene for your excellent explanations. I was able to diagnose a problem with my defrost thermostat. You may want to mention that it is also called a Bimetl - def. It will take a week for my part to arrive.
Running the refrigerator without the back panel in the freezer affecting a proper cold air distribution in both sections of the refrigerator. You have to put it back together if you prefer not to wait till the new part arrives. Gene.
