tsdixon
#1 Posted : Thursday, July 23, 2009 8:13:11 AM(UTC)
tsdixon
Ice and water are in the door. Ice will only come out as crushed either on crushed option and on cubed option. Can't get any cubed ice to come out only crushed.
applianceman
#2 Posted : Thursday, July 23, 2009 10:23:58 AM(UTC)
applianceman
If you take the ice bucket out and look behind it you should see a little hole (about an inch) that a metal lever (from the ice bucket) goes into. What happens is when you want cubes a solenoid will lift that rod up. Open the door (with the ice bucket out) press the door switch and press the button to get ice. You should see the solenoid lift up and if you don’t the solenoid may be bad. If it does lift up post back and we will go from there. Refrigerator repair guide
tsdixon
#3 Posted : Thursday, July 23, 2009 11:13:46 AM(UTC)
tsdixon
You're right, the solenoid must be bad. Can you tell me that part number?
Thank you
applianceman
#4 Posted : Thursday, July 23, 2009 11:48:44 AM(UTC)
applianceman
Part Details - GE Solenoid & arm assembly, part number: WR62X58 Here is a link to it. Reach in and try to lift it up by hand. Will it lift up?
tsdixon
#5 Posted : Thursday, July 23, 2009 12:20:03 PM(UTC)
tsdixon
Yes, I can move it. In fact I moved it up and it will produce cubes, but it makes a loud funny noise when on cube option. Doesn't make crazy sound on crush option. Whata ya think?
applianceman
#6 Posted : Thursday, July 23, 2009 3:03:50 PM(UTC)
applianceman
I have been thinking the whole time the solenoid was bad but try one more thing before we call it. Pull the ice bucket out and attempt to move the metal lever up and down just to be sure that part isn’t stuck. It sounds to me like one of the two parts is stuck either the solenoid or the metal rod. I believe it is the solenoids since it wouldn’t work with the ice bucket out I think the solenoid is bad or frozen.
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
