Ice and water are in the door. Ice will only come out as crushed either on crushed option and on cubed option. Can't get any cubed ice to come out only crushed.
If you take the ice bucket out and look behind it you should see a little hole (about an inch) that a metal lever (from the ice bucket) goes into. What happens is when you want cubes a solenoid will lift that rod up. Open the door (with the ice bucket out) press the door switch and press the button to get ice. You should see the solenoid lift up and if you don’t the solenoid may be bad. If it does lift up post back and we will go from there. Refrigerator repair guide
You're right, the solenoid must be bad. Can you tell me that part number? Thank you
Yes, I can move it. In fact I moved it up and it will produce cubes, but it makes a loud funny noise when on cube option. Doesn't make crazy sound on crush option. Whata ya think?
I have been thinking the whole time the solenoid was bad but try one more thing before we call it. Pull the ice bucket out and attempt to move the metal lever up and down just to be sure that part isn’t stuck. It sounds to me like one of the two parts is stuck either the solenoid or the metal rod. I believe it is the solenoids since it wouldn’t work with the ice bucket out I think the solenoid is bad or frozen.
