When I shut the freezer door, the ice dispenser dispenses 1 or 2 cubes of ice. I can tell that the ice screw turns about 90 degrees and then stops just after shutting the freezer door. I pulled the ice container out fron inside the freezer in order to observe the screw drive mechanism. I can shut the door and open it quickly to actually see the screw drive move. Also the dispensing light comes on (front outside of frig freezer door) for a split second when the door is closed. Could it be the power board or board control. I did take the dispenser apart to do some trouble shooting. Maybe I damaged circuit bourd without knowing it?
