Kids left freezer door open. I noticed and shut tightly. Shortly afterward I noticed no ice was being made. I removed icemaker and cleaned out the ice that was in it. I dried it and re-installed. I checked the water inlet and it was not frozen. I plugged frig back in and noticed no water going to ice maker and also that the auger had not moved either. Any advice?
Check your freezer back wall temperature, must be below 15 degrees.
