wartrue
#1 Posted : Monday, July 20, 2009 5:54:06 AM(UTC)
wartrue
Views messages in topic : 4
I can see the starter trying to light the dryer, but no ignition. I think it went out during a cycle last nite. Now, of course, it just blows cold.
Any help would be appreciated.
Wartrue
#2 Posted : Monday, July 20, 2009 4:50:39 PM(UTC)
If the igniter glows but it does not light the gas then the problem most likely is a bad gas valve coils (#13 & #14 on the diagram).
If the igniter stays "off" then The first thing I would do is check the thermal fuse (#7 on the diagram) for continuity.
- The gas valve coil kit Part number: AP3094251
- The thermal fuse Part number: AP3132867
wartrue
#3 Posted : Tuesday, July 21, 2009 6:51:10 AM(UTC)
wartrue
Thanks for the info. I'll try the fixes you've suggested & let you know how it turns out.
You guys are the BEST!!
Thanks again, wartrue
Gas dryer won't light (Dryer Repair)
by tseibring 12/23/2016 1:45:50 PM(UTC)
Maytag dryer won't light (no heat) (Dryer Repair)
by loulac01 7/9/2012 11:58:00 AM(UTC)
Gas Dryer won't light or heat up (Dryer Repair)
by jimtowndave 1/12/2012 10:55:09 AM(UTC)
Dryer won't light (Dryer Repair)
by Joey2871 12/8/2011 7:24:33 AM(UTC)
gas dryer won't light (Dryer Repair)
by Boyfinn 12/3/2011 9:01:23 AM(UTC)
Whirpool dryer won't light (Dryer Repair)
by stinky5759 2/18/2010 3:30:08 PM(UTC)
Gas dryer won't light. No spark. (Dryer Repair)
by randy1 9/8/2008 2:03:20 PM(UTC)
Kenmore Gas Dryer Won't Light (Dryer Repair)
by JohnF 9/11/2007 1:50:10 AM(UTC)
