I can see the starter trying to light the dryer, but no ignition. I think it went out during a cycle last nite. Now, of course, it just blows cold. Any help would be appreciated. Wartrue
If the igniter glows but it does not light the gas then the problem most likely is a bad gas valve coils (#13 & #14 on the diagram). If the igniter stays "off" then The first thing I would do is check the thermal fuse (#7 on the diagram) for continuity. - The gas valve coil kit Part number: AP3094251
Thanks for the info. I'll try the fixes you've suggested & let you know how it turns out. You guys are the BEST!! Thanks again, wartrue
