nikita
#1 Posted : Sunday, July 12, 2009 6:56:07 PM(UTC)
nikita
what else can i say? my gas dryer does not start; its as if its not pluged in. please help!
kayakcrzy
#2 Posted : Monday, July 13, 2009 4:10:33 AM(UTC)
kayakcrzy
You either have no power coming to the dryer. So if you have a volt meter, check the power where the plug goes into the dryer for proper power. You could also try to flip the dryer breaker off and on a few times, and then check it. Also, the door switch could be bad. Tom www.applianceeducator.com:cool:
nikita
#3 Posted : Monday, July 13, 2009 5:00:54 AM(UTC)
nikita
Tom, i obviously checked the power, and the door switch. could it be the thermal switch???
kayakcrzy
#4 Posted : Tuesday, July 14, 2009 3:22:38 AM(UTC)
kayakcrzy
On a gas dryer, the thermal fuse will only stop the ignitor coil from coming on if it were bad. On an electric dryer it would shut the whole thing down. Tom ApplianceEducator.com
nikita
#5 Posted : Tuesday, July 14, 2009 5:09:55 AM(UTC)
nikita
ok then, what do you think the problem is if its NOT the thermal fuse. (it is a gas dryer). as i mentioned, there is NO response to pushing the start button, no matter what settings everything else is on. any ideas???
kayakcrzy
#6 Posted : Tuesday, July 14, 2009 5:23:18 AM(UTC)
kayakcrzy
I wouk jump out the door switch. It usually is not a timer when it is dead! Jump out the door switch, and see if it comes on. If you have a ohm meter, ohm out the thermostats and see if they have continuity. Tom
electric dryer does not start (Microwave Repair)
by RayU 12/12/2013 7:03:52 PM(UTC)
Dryer does not start (Dryer Repair)
by Kalalau 9/20/2012 12:20:37 PM(UTC)
by hibidwns 6/25/2012 1:44:16 PM(UTC)
by Bharat 1/7/2012 4:02:37 PM(UTC)
Dryer does not start, can hear motor attempting to (Dryer Repair)
by bog 11/5/2011 9:52:03 AM(UTC)
by Raymond S 8/4/2011 8:35:52 AM(UTC)
by cpboudreaux 2/15/2011 8:59:37 AM(UTC)
Dryer does not start - Amana Gas (Dryer Repair)
by timjgtr 1/8/2011 10:10:33 AM(UTC)
Dryer does not start at all (Dryer Repair)
by timjgtr 12/26/2010 2:40:08 PM(UTC)
Gae Dryer Does Not Start (Dryer Repair)
by B Wall 9/10/2010 7:03:40 AM(UTC)
by D_Druz 3/1/2010 4:41:38 PM(UTC)
Dryer does not start, makes no sound (Dryer Repair)
by Pennell 11/12/2009 5:17:16 PM(UTC)
dryer does not start (Dryer Repair)
by petecardenas 10/19/2009 8:17:02 AM(UTC)
by petecardenas 10/19/2009 8:15:29 AM(UTC)
by bellaboo 10/1/2009 1:16:49 PM(UTC)
