fxn001
#1 Posted : Monday, July 13, 2009 6:37:55 AM(UTC)
fxn001
Dryer would not heat. Every time I replace a part it works fine for a few loads then stops heating again.
I replaced the thermal fuse - watched the igniter glow and light the gas. Put it all back together, ran two loads fine then it stopped heating.
Replaced the thermostat (the one on the heater box). Watched the igniter glow and light the gas. Put it all back together, ran two more loads and then it stopped heating.
Opened the back again and noticed the connector to the newly replaced thermostat was loose. I tighted it up, watched the igniter glow and light the gas. Put it all back together, ran a load fine and then it stopped heating again.
What should I look at next?
Prof. Maneuver
#2 Posted : Monday, July 13, 2009 12:18:53 PM(UTC)
Prof. Maneuver
Sir-
How about airflow obstructions everywhere including the exhaust obviously, then jumper around the T-stats/T-fuse one at a time and see if it lights, failing that, flame sensor? Not really sure how that works, could be hazardous to defeat!
Good Luck to You,
Steve
Maytag MEDC200XW1 - Intermittent heat and no buzzer (Dryer Repair)
by Lemarac 1/9/2019 4:09:17 PM(UTC)
electric dryer intermittent heat (Dryer Repair)
by wags1970 7/11/2017 9:31:33 AM(UTC)
gas dryer with intermittent heat (Dryer Repair)
by highpoint 1/21/2017 12:14:48 PM(UTC)
Intermittent Heating (Dryer Repair)
by lccent 8/7/2015 9:19:56 AM(UTC)
Intermittent heating. Now none. (Microwave Repair)
by bstruss 2/23/2015 6:29:10 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
by colbey 7/11/2014 4:55:38 PM(UTC)
LG electric dryer Intermittent Heat (Dryer Repair)
by Saurin 10/2/2013 7:41:23 PM(UTC)
by greg.od11@gmail.com 8/21/2013 3:29:48 PM(UTC)
Gas Dryer Intermittent Heat (Dryer Repair)
by FranDaMan 7/4/2013 6:53:18 PM(UTC)
by gvel 5/19/2013 3:38:09 PM(UTC)
Gas Dryer - Intermittent heat, checked coils and igniter (Dryer Repair)
by nevets 11/18/2012 6:14:02 PM(UTC)
by rcady52 10/26/2012 12:03:54 PM(UTC)
Whirlpool Super Capacity 465 Oven...intermittent heating issue (Oven Repair (including Ranges and Cooktops))
by wetzelbp 9/3/2012 4:25:33 PM(UTC)
Maytag Dryer Intermittent Heat (Dryer Repair)
by jayjaysin 6/24/2012 4:59:26 PM(UTC)
