2 Pages12>
skippie
#1 Posted : Friday, July 10, 2009 4:43:36 AM(UTC)
skippie
Not cooling none of it Its a side by side and never side is cooling.Just happen all at once
skippie
#2 Posted : Friday, July 10, 2009 4:44:45 AM(UTC)
skippie
Refrigerator not cooling not even the freezer happen all at once
woodchuckie
#3 Posted : Friday, July 10, 2009 5:24:29 AM(UTC)
woodchuckie
Is the compressor motor running.
Check to see if the condenser fan at the back underneath near the compressor is running.
Are the condenser coils near there warm or room temp
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
skippie
#4 Posted : Friday, July 10, 2009 8:59:16 AM(UTC)
skippie
Yes the motor is running seem like the copresser is kicking in
woodchuckie
#5 Posted : Friday, July 10, 2009 9:30:54 AM(UTC)
woodchuckie
skippie
#6 Posted : Friday, July 10, 2009 9:35:42 AM(UTC)
skippie
Yes the fan is running and I also put another fan back there to help see if it will work.Can`t get the air to goo over to the refrigerator side for some reason but it still don`t tell me why the freezer not working.Just check everything seem to be working .
skippie
#7 Posted : Friday, July 10, 2009 10:07:45 AM(UTC)
skippie
woodchuckie
#8 Posted : Friday, July 10, 2009 2:39:57 PM(UTC)
woodchuckie
If the condenser coils near the compressor and fan underneath are not warm that mean the compressor is not running or if it is it is low on freon or not pumping freon. This requires a qualified tech to service.
If those coils are warm then the evaporator coils inside the freezer behind the back panel should be cool or cold and some cooling going on in the freezer. There is a fan above these coils which blows the cold air to the fridge side through a vent.
skippie
#9 Posted : Friday, July 10, 2009 3:32:26 PM(UTC)
skippie
Yes There Is Some Freezing Down On The Bottom Part Of The Freezer.does This Mean Low On Freon Or What
skippie
#10 Posted : Friday, July 10, 2009 3:45:54 PM(UTC)
skippie
The Coil In The Freezer Behind The Panel Is All Frooze Up And The Lines Too
Guest (5)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Frigidaire Refrigerator, not cooling (Refrigerator & Freezer Repair)
by Guest 7/31/2022 11:09:46 AM(UTC)
Frigidaire Refrigerator Fan(s) Inside Cycling On And Off To Get Started (Refrigerator & Freezer Repair)
by JamesDIY 4/28/2022 1:25:48 AM(UTC)
Frigidaire Refrigerator GLHS268ZDS2 (Refrigerator & Freezer Repair)
by Pursue 10/26/2021 2:10:36 PM(UTC)
Frigidaire Refrigerator FFTR1814LW9 (Refrigerator & Freezer Repair)
by Guest 10/11/2021 9:30:20 AM(UTC)
Frigidaire refrigerator handle (Appliance Parts)
by Eastwezt 8/20/2021 10:04:25 AM(UTC)
2003 Frigidaire Refrigerator (Refrigerator & Freezer Repair)
by Guest 6/25/2021 5:52:53 PM(UTC)
Model FRS23H5ASB8 Frigidaire Refrigerator issue (Refrigerator & Freezer Repair)
by Johnnyvirgil 2/15/2021 9:20:33 AM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Frigidaire Refrigerator LGHT1846QP1 - door switch and cabinet cooling (Refrigerator & Freezer Repair)
by BJPrice 10/26/2020 5:28:12 AM(UTC)
Frigidaire refrigerator model # FRT18S6AW9 (Refrigerator & Freezer Repair)
by rlundin@nycap.rr.com 6/29/2020 4:32:36 PM(UTC)
Frigidaire Refrigerator FGHS2644KF1 (Refrigerator & Freezer Repair)
by Shutterbug962 5/23/2020 12:51:57 PM(UTC)
My Frigidaire Refrigerator stopped workin (Refrigerator & Freezer Repair)
by justme0987 4/8/2020 12:18:43 PM(UTC)
2 Pages12>
