Alan Egbert
#1 Posted : Friday, July 10, 2009 3:33:46 AM(UTC)
Alan Egbert
I have an Estate Dryer, that wont come on. I have checked the door, switch, power, thermal fuse, push on switch, blower wheel, and the motor seems to turn freely. when it is plugged in the heating element heats until you turn it to the off position. Can you help me?
Alan
kayakcrzy
#2 Posted : Friday, July 10, 2009 4:35:51 AM(UTC)
kayakcrzy
Originally Posted by: alan egbert Go to Quoted Post
i have an estate dryer, that wont come on. i have checked the door, switch, power, thermal fuse, push on switch, blower wheel, and the motor seems to turn freely. when it is plugged in the heating element heats until you turn it to the off position. can you help me?
alan
be sure you are over looking the thermal fuse in the rear. the white one, that is an inch and a half long by a half inch wide. on the element coming on, it is either grounded to the case, or you have a stuck motor switch, alowing power to go to the element. which means, you need to replace the motor. pull the element first. tom www.applianceeducator.com/parts.htm:cool:
Dryer wont come on (Dryer Repair)
by sagen 12/16/2007 10:29:37 AM(UTC)
by sagen 12/16/2007 8:44:56 AM(UTC)
by sagen 12/15/2007 5:22:00 PM(UTC)
