George Madden
#1 Posted : Thursday, January 3, 2008 2:14:56 PM(UTC)
George Madden
The exaust fan runs at high speed only. Can you advise what part is needed. I assume the touch panel may be gone?.
Thanks you
George Madden
#2 Posted : Thursday, January 3, 2008 2:18:07 PM(UTC)
What it does when you try to switch on low speed?
George Madden
#3 Posted : Thursday, January 3, 2008 2:56:07 PM(UTC)
George Madden
Gene the fan stays on high when I hit the low speed button or any other button. Ours has a Fan boast button as well and hitting that doesn't make any difference either.
Thanhks Again
George Madden
#4 Posted : Thursday, January 3, 2008 3:01:07 PM(UTC)
George,
Does it beep?
Does it show anything on the display?
George Madden
#5 Posted : Thursday, January 3, 2008 3:33:08 PM(UTC)
George Madden
George,
Does it beep?
Hi Gene
Yes it beeps every time I hit the control button. The display shows high, medium and low speeds. Whe I hit the Boast button that shows in display also. I can't thank you enough for your expertise help.
Sincerely
George M
#6 Posted : Thursday, January 3, 2008 4:07:55 PM(UTC)
George,
Most likely the problem is the control board (aka Printed Circuit Board).
- The part number for the control board is AP3192717
- Here are the break down diagrams for the GE microwave Model JVM1860WD001
Good luck.
George Madden
#7 Posted : Thursday, January 3, 2008 4:25:21 PM(UTC)
George Madden
Gene I can't thank you enough for your help it is most appreciated. If you could give me your email address I will let you know how I make out.
Sincerely
George M
#8 Posted : Thursday, January 3, 2008 4:31:04 PM(UTC)
George,
The Admin of this forum does not let us to post our e-mails.
Just post the results here and I'll see it.
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
Belarus Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
