sharp
#1 Posted : Thursday, January 3, 2008 11:12:58 AM(UTC)
sharp
:confused: Just got the washer from a friend.....the washer will not spin, it goes thru all the cycles. But, when it starts to spin it makes a loud "clanging noise"...and other times, it does not make the noise, but will not spen..we would appricate some ideas..thanks
#2 Posted : Thursday, January 3, 2008 11:25:48 AM(UTC)
Does it drain?
sharp
#3 Posted : Thursday, January 3, 2008 11:36:51 AM(UTC)
sharp
yes,it drains all, except what is in the clothes.
#4 Posted : Thursday, January 3, 2008 12:16:17 PM(UTC)
Most likely the problem is a bad motor drive coupling (#13 on the motor and pump break down diagram).
- The part number for the motor drive coupling is AP3963893
- Here are the break down diagrams for the Roper washer Model RAL5144AL0
Good luck.
Guest (4)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
