ribwholesalers
#1 Posted : Wednesday, July 8, 2009 1:44:21 PM(UTC)
ribwholesalers
my dryer sometimes lights up for heat and sometimes does not. the burner assembly glows, but sometimes there is no ignition, and the glow stops. I am thinking either the flame sensor, or the igniter. And trying to determine which part might act like that
#2 Posted : Thursday, July 9, 2009 3:00:08 AM(UTC)
I would look for a burnt wire, if none, I would replace the flame sensor and the igniter. Igniter AP3094138, flame sensor AP2910747. If you have an amprobe, igniter current should be over 3 amp.
Dryer heat problems (Dryer Repair)
by gmckinley 6/14/2013 8:46:54 PM(UTC)
intermittent dryer heat problem (Dryer Repair)
by busterhead 10/19/2012 2:28:25 AM(UTC)
gas dryer heat problem (Dryer Repair)
by SPRISL 7/6/2010 10:53:01 AM(UTC)
by wtelwe 2/10/2009 6:42:48 PM(UTC)
Dryer heat problem (Dryer Repair)
by Dale 10/1/2007 3:14:13 PM(UTC)
