notapro
#1 Posted : Monday, July 6, 2009 5:11:32 PM(UTC)
notapro
Wondering what the problem could be. Wash machine will not drain or spin. Help!
Thanks, Mike
sidfink43
#2 Posted : Wednesday, July 8, 2009 8:35:16 AM(UTC)
sidfink43
See if you can find a tech sheet under the top or behind the front panel. This will take you through a diagnostic test.
Most likely is your central control unit or your motor (speed) control.
notapro
#3 Posted : Thursday, July 9, 2009 4:54:04 PM(UTC)
notapro
Thank you very much I will look for this.
#4 Posted : Friday, July 10, 2009 3:08:37 AM(UTC)
You also could just have a clogged filter inside the tub drain. Remove the connection to the pump and check. If it is filled with stuff, you will probably need to remove the tub clamp. These wire clamps ar very hard to replace, I usually use a band hose clamp instead. If you need a pump, AP4359998
notapro
#5 Posted : Saturday, July 11, 2009 1:45:07 AM(UTC)
notapro
I have removed the filter and found nothing inside. However if the pump is bad wont the machine still start to spin?
#6 Posted : Saturday, July 11, 2009 2:17:43 AM(UTC)
Measure the voltage to the pump during spinnout. If voltage, but no pumping, you have a bad pump. I think your washer will not spin till the water is pumped out.
Hotpoint wont spin or drain (Washer Repair)
by Snowostrich 7/1/2017 2:53:32 PM(UTC)
Washer wont spin or drain (Washer Repair)
by steelem@myomnitel.com 2/3/2014 10:20:19 AM(UTC)
washer wont spin or drain (Washer Repair)
by hunter02 7/15/2013 10:36:02 PM(UTC)
by dionnaorner 4/11/2013 5:27:51 PM(UTC)
Washer Wont Spin Or Drain (Washer Repair)
by tammy924 1/17/2013 10:11:49 AM(UTC)
dishwasher wont spin or drain (Dishwasher Repair)
by jbenn 6/4/2012 7:12:32 PM(UTC)
My washer wont spin or drain (Washer Repair)
by Elizabeth2323 4/5/2012 5:15:32 PM(UTC)
Washer With Ratcheting Sound Wont Spin Or Drain (Washer Repair)
by DANI1 3/22/2012 10:48:51 AM(UTC)
frigadaire FTF2140SF1 wont spin or drain (Washer Repair)
by ptb204 6/8/2011 8:23:14 AM(UTC)
whirlpool washer will agitate, but wont spin or drain (Washer Repair)
by robert garbacz 4/8/2011 4:25:26 PM(UTC)
by mastercylinder 3/29/2011 5:42:23 PM(UTC)
roper washer wont spin or drain water (Washer Repair)
by michalek 3/28/2011 6:59:22 PM(UTC)
by rday 11/1/2009 7:07:27 PM(UTC)
washing machine wont spin or drain (Dishwasher Repair)
by williemc 6/14/2009 2:00:48 PM(UTC)
Whirlpool wont spin or drain (Washer Repair)
by SunySydeofLyfe 5/17/2009 7:28:04 PM(UTC)
