Would love some advice please!
Ice maker seems to operating properly except for it does not seem to fill itself up with water. The dispenser seems to cycle through fine, but just doesn't get any water. However, the water dispenser on the front of the fridge works fine. I believe the problem started when I turned off the water to the fridge for a couple of days. Thoughts?
Also, is it normal for the front of the freezer to feel cool/cold? Occassionaly it will get condensation on the outside of the freezer
Any help would be great! Thanks!!!
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear
