pacas37
#1 Posted : Sunday, July 5, 2009 6:13:19 AM(UTC)
pacas37
Dryer will not turn on. The control lock light is dimly lit up. The dispaly shows two faint dashes.
sidfink43
#2 Posted : Sunday, July 5, 2009 6:50:16 AM(UTC)
sidfink43
Take off the bottom panel and you should find a tech sheet which will show you how to go into test mode.
If you cannot get the machine to go into test mode your problem is likely (but not certainly) in your user interface board.
Good luck, Let us know what you find out.
pacas37
#3 Posted : Sunday, July 5, 2009 8:16:29 AM(UTC)
pacas37
It will not go into test mode. Which board is bad? The one with the buttons or the on that sits inside the machine up on top?
sidfink43
#4 Posted : Sunday, July 5, 2009 8:46:31 AM(UTC)
sidfink43
We are dealing with probability here, with the interace board (the one with buttons) being the logical culprit. Unfortunately it could be the control board, or even both.
As you have probably guessed, a service tech has the boards in the truck and merely changes them out until the problem is solved, but you do not have that luxury. If you want to try to fix it you will have to try a board at a time, but I think it is likely the interface board will solve your problem. If not you will have to go to the control board.
Since both of these are pretty costly, you will need to think about whether or not try the repair. This is a pretty good dryer when it works, so I would go for it.
Good luck, let us know how it turns out.
pacas37
#5 Posted : Sunday, July 5, 2009 9:22:49 AM(UTC)
pacas37
It was working when I would shut the power off, wait 30 minutes and turn the breaker back on. The dyer would run the cycle and then you would have to reset with the breaker.
Leon Warner
#6 Posted : Sunday, June 6, 2010 9:48:48 AM(UTC)
Leon Warner
I see several people have had this problem with the control lock keeping the dryer from starting. Holding the button 3 seconds and unplugging to reset doesn't work. What was the fix? :confused:
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Whirlpool duet dryer issue (Dryer Repair)
by Wes13 12/15/2021 3:54:09 PM(UTC)
Duet Mod# GE9200LW1 Whirlpool Duet dryer (Dryer Repair)
by Guest 11/17/2021 6:59:07 PM(UTC)
Whirlpool duet dryer making clicking noise (Dryer Repair)
by Ctiong916 4/23/2021 9:00:11 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Whirlpool Duet dryer - no heat (Dryer Repair)
by colino 3/19/2018 10:56:53 AM(UTC)
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Whirlpool Duet Dryer Grinding Sound (Dryer Repair)
by mintken 10/16/2016 8:31:42 AM(UTC)
Whirlpool Duet Dryer won't start (Dryer Repair)
by berthettah 7/21/2016 10:10:39 AM(UTC)
Whirlpool duet dryer (Dryer Repair)
by norbreym28 7/16/2016 8:29:04 AM(UTC)
Whirlpool Duet Dryer F02 and F70 codes (Dryer Repair)
by esnyder 7/6/2016 1:18:43 PM(UTC)
Whirlpool Duet Dryer Error Code f25 (Dryer Repair)
by wwwhitley 10/30/2015 12:09:40 PM(UTC)
