gary15f
#1 Posted : Friday, July 3, 2009 9:18:21 PM(UTC)
gary15f
dryer runs but there is no heat, blows cold air at vent.circuit brakers on.
sidfink43
#2 Posted : Sunday, July 5, 2009 6:32:43 AM(UTC)
sidfink43
Hi Gary
Even if the circuit breakers are on you need to check to see that you are getting 120 v to each outside terminal on the connection block.
If so, your problem is like in the thermal fuse, which you can check for continuity. If that checks out, check the other thermal devices (thermostats) and if they check out, check the heating element for resistance and continuity and make certain it is not broken or grounded.
Somewhere in there should solve your problem, let us know if you need more info.
whirlpool dryer no heat (Dryer Repair)
by dlctac 4/2/2012 10:07:47 AM(UTC)
by McAndrew11 3/3/2012 9:13:51 AM(UTC)
Whirlpool Dryer no heat (Dryer Repair)
by gunworks 12/21/2011 4:03:17 PM(UTC)
by boyerjr 4/1/2011 12:44:44 PM(UTC)
whirlpool dryer no heat new everything (Dryer Repair)
by blainesr 1/6/2010 5:47:42 PM(UTC)
by donswife_1998 12/20/2009 5:54:00 PM(UTC)
Whirlpool dryer no heat & timer wont shut off (Dryer Repair)
by lsaustin 6/20/2009 8:13:47 AM(UTC)
by looie 9/30/2008 11:51:43 AM(UTC)
