looie
#1 Posted : Tuesday, September 30, 2008 11:51:43 AM(UTC)
looie
No heat but element looks OK. Also timer doesn't work. New timer did not help. Any ideas?
libertyappl
#2 Posted : Tuesday, September 30, 2008 1:25:16 PM(UTC)
libertyappl
does the dryer drum turn?
Have you tried all settings/cycles?
Test the thermstats on the heater box with an ohm meter for continuity.
Nat
looie
#3 Posted : Tuesday, September 30, 2008 3:56:14 PM(UTC)
looie
Drum turns, no settings work (time or heat), thermostats and element test good. When I replaced timer did I just get a bad one? Anything else I could check? Much appreciated!
libertyappl
#4 Posted : Tuesday, September 30, 2008 6:54:42 PM(UTC)
libertyappl
Check your plug to make sure you have 220V. And check your breaker turn it off and then back on, sometimes they can be parially tripped and look normal.
Nat
whirlpool dryer no heat (Dryer Repair)
by dlctac 4/2/2012 10:07:47 AM(UTC)
by McAndrew11 3/3/2012 9:13:51 AM(UTC)
Whirlpool Dryer no heat (Dryer Repair)
by gunworks 12/21/2011 4:03:17 PM(UTC)
by boyerjr 4/1/2011 12:44:44 PM(UTC)
whirlpool dryer no heat new everything (Dryer Repair)
by blainesr 1/6/2010 5:47:42 PM(UTC)
by donswife_1998 12/20/2009 5:54:00 PM(UTC)
by gary15f 7/3/2009 9:18:21 PM(UTC)
Whirlpool dryer no heat & timer wont shut off (Dryer Repair)
by lsaustin 6/20/2009 8:13:47 AM(UTC)
