No heat but element looks OK. Also timer doesn't work. New timer did not help. Any ideas?
does the dryer drum turn? Have you tried all settings/cycles?
Test the thermstats on the heater box with an ohm meter for continuity.
Nat
Drum turns, no settings work (time or heat), thermostats and element test good. When I replaced timer did I just get a bad one? Anything else I could check? Much appreciated!
Check your plug to make sure you have 220V. And check your breaker turn it off and then back on, sometimes they can be parially tripped and look normal. Nat
