The control panel has gone blank, clock display out, the light inside works when unit is turned on, checked fuse anyway and it's good. Could it be something other than the control panel?:mad:
Most likely the problem is a bad control board. The model number you posted does not come up, but I'm afraid the part for a such old microwave is no longer available.
No the display is blank and none of the keypad numbers make any affect and it doesn't start either. It was good and then all of a sudden it didn't work just like something just burned out.
