207 Pages«<4344454647>»
lvig
#441 Posted : Monday, June 29, 2009 7:42:39 AM(UTC)
lvig
I found out an answer to my question
thank you
dlimanov
#442 Posted : Monday, June 29, 2009 6:23:41 PM(UTC)
dlimanov
thank you
Wanna share? :)
rbcole123
#443 Posted : Tuesday, June 30, 2009 7:32:50 AM(UTC)
rbcole123
Hi, can someone tell me where the condenser coils are located on this model. I believe it is in the back (have to unscrew metal bracket), but I'm not sure. Amazingly, GE has no appliance tech support and the owner's manual does not identify. Thanks!
woodchuckie
#444 Posted : Tuesday, June 30, 2009 8:58:57 AM(UTC)
woodchuckie
Diagram 3 shows the evaporator behind the cover in the back of the freezer.
Replacement parts for GE PTS25SBMARBS | AppliancePartsPros.com
huntindad
#445 Posted : Tuesday, June 30, 2009 7:16:21 PM(UTC)
huntindad
I have the same type of symptoms. I have an Amana top fridge with bottom freezer. Model is BX21VW.
I have noticed some frost on the inside of the back of the freezer.
However, looking thru the parts list, I did not see a defrost timer.
I'm guessing I need to pull the back panel off and see what it looks like.
Any ideas on this Amana? Parts seem to be made by Whirlpool.
thanx,
DAvid
JeffG.
#446 Posted : Tuesday, June 30, 2009 9:31:38 PM(UTC)
JeffG.
I have a Sears Coldspot 106-7660620 and I cannot find the diagrams. The problem is a defrost issue. I took it apart, saw the ice blockage and did the quick thaw with a hair dryer
Do you have the diagrams for this particular model?
Edit: Woke up this morning and the fridge is still only on 42F, maybe the problem is something
else?
Edit: Temp continued to fall and the fridge is well within optimum range now.
Thanks!
Jeff G.
sam smith
#447 Posted : Thursday, July 2, 2009 3:54:54 PM(UTC)
sam smith
I have a similar concern. I have a GE fridge, bottom freezer around 10-20 degrees. fridge works fine. After reading through this thread I got GE to send me a motherboard, wr55x10656 (w/ instructions for wr55x10552, update for that board?) I installed the board, not cutting the thermistor and capacitor wire. The wire were not present on my fridge. Now the freezer is around 7-8 degrees (after 24 hours) and the fridge is about 3 degrees what i set it to be. Any ideas? there were some yellowish liquard/water underneath the condensor? after the new board it's dry. there's a fan blowing on it, so I'm assuming it's a condensor. I expect to see some moisture on an evaporator, but not a condensor? Any help? thank you.
*I understand the concept of automotive a/c systems so I have a question. If there's a freon leak, would it not affect the fridge side? and I'm assuming the freezer would continue to get warmer and not cool down due to low freon levels correct?
#448 Posted : Thursday, July 2, 2009 6:54:27 PM(UTC)
thanx,
DAvid
David,
The defrost timer is #342 on the diagram. Looks like it's behind the bottom front grill.
#449 Posted : Thursday, July 2, 2009 7:12:01 PM(UTC)
else?
Thanks!
Jeff G.
Jeff,
The defrost timer in your refrigerator is incorporated in the ice maker.
If the continuity test for the defrost thermostat and the defrost heater would not show anything wrong then the ice maker has to be replaced.
- The part number for the ice maker is AP3154714
#450 Posted: : Thursday, July 2, 2009 7:14:50 PM(UTC)
Sam,
What is the complete model number of the refrigerator?
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
