seymore
#1 Posted : Monday, June 29, 2009 9:56:53 AM(UTC)
seymore
this the second time we are replacing the heat defroster my concerns are 1-why this part has such a short life 2-should we replace it or think about a new refrigator 3-is it something i can do myself
woodchuckie
#2 Posted : Monday, June 29, 2009 10:47:22 AM(UTC)
woodchuckie
You can probably do it yourself, but are you sure it's bad. If your defrost system isn't working it could also be the defrost thermostat or the motherboard
How to check the defrost thermostat and heater. If they are OK the problem is the motherboard. >Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
#3 Posted : Monday, June 29, 2009 11:56:10 AM(UTC)
Just to add my 2 cents...
You also can perform the troubleshooting right from the main control board (#801 on the diagram). Use the instructions from one of our previous posts: http://forum.appliancepartspros...igerator-too-warm-3.html (the reply addressed to Bohemian).
Here are the breakdown diagrams and Replacement parts for GE GSS22JFPHWW | AppliancePartsPros.com
