jsantilli
#1 Posted : Saturday, June 27, 2009 3:18:47 PM(UTC)
jsantilli
Maytag neptune electric dryer MDE7500AYW shows power failure occured when I try to start it. I reset it and and keeps doing it. What should I check or do?
#2 Posted : Sunday, June 28, 2009 7:45:32 AM(UTC)
Replacement parts for MAYTAG MDE7500AYW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Cannot be of much help here hopefully someone else with more knowledge will jump in.
I am not sure how they monitor the power so the best I can do is suggest you check all the electrical connections (plug, receptacle etc.) and the connections in the unit.
You could try getting into the diagnostics to see if anything pops up.
The following may be worth a try:
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
maytagrepair1
#3 Posted : Sunday, June 28, 2009 2:02:56 PM(UTC)
maytagrepair1
I just checked the thermal fuses. and they are fine. I checked the door switch as well. I think the dryer stopped functioning after the thunderstorm. Is there a PCB or control board that could be fried?
is there a place i can locate the service manual for this....
Thanks...so much..
jsantilli
#4 Posted : Monday, June 29, 2009 5:11:51 AM(UTC)
jsantilli
Gene, thanks for the infor. My problem seems to come and go. If I keep trying to start the dryer it clicks and screen shows power failure occured. It sounds like a relay is trying to kick in but then kicks out. I continue to reset it and try again. After reseting it 3-4 times it works. Serveral weeks goand it acts up again with the same problem. So far I keeping reseting and it seems to keep working. I figure it's only a matter of time before it fails completelyl
magician59
#5 Posted : Monday, June 29, 2009 7:27:04 AM(UTC)
magician59
Originally Posted by: denman Go to Quoted Post
Unplug the unit
Open it up
Hey, denman: Your response here reminded me that quite a few years ago (less than ten), I saw a fixture that techs can use to do continuity tests on ribbon connectors. Do you remember such a tool? I've tried unsuccessfully to locate it.
#6 Posted : Monday, June 29, 2009 7:33:15 AM(UTC)
magician 59
Sorry have never heard of it.
Perhaps try a post in the tech forum.
magician59
#7 Posted : Monday, June 29, 2009 7:36:00 AM(UTC)
magician59
You said the definitive word: Thunderstorm. I would recommend you do a visual check on the circuit board in the console. [COLOR="Red"]Unplug it first[/COLOR]. See if there is any obvious burning of any component on the board. Inside the console you should also find the tech sheet (unless a previous tech stole it--that's one of my pet peeves). It should offer some basic troubleshooting and info about diagnostic mode.
Guest (6)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
