longashes
#1 Posted : Thursday, June 25, 2009 12:02:41 PM(UTC)
longashes
When I turn the control dial to start the dishwasher, at the "Start" point I can feel a small vibration but no water starts. I have pulled the panel and can rotate the fins on the motor freely.
What happens at the very first step when you turn to "Start"? That is what appears to be broken.
Thanks.
#2 Posted : Thursday, June 25, 2009 7:48:13 PM(UTC)
Originally Posted by: longashes Go to Quoted Post
...What happens at the very first step when you turn to "Start"?...
The dishwasher should get water at that time. Sounds like the problem is a bad dishwasher water inlet valve or a water shut off valve under the sink.
Here are the breakdown diagrams and Replacement parts for GE GSD3230ZZ3WW | AppliancePartsPros.com
longashes
#3 Posted : Friday, June 26, 2009 3:19:33 AM(UTC)
longashes
Thanks Gene. Any way to validate it besides replacement?
#4 Posted : Friday, June 26, 2009 5:14:29 AM(UTC)
Loosten the water line to it to verify water to it. If water, then it could be a jamed float, bad timer, or a bad water solenoid. If you can feal the water valve vibrating, you may have stuff clogging it. Just pull it out and replace it.
