Eduardo 71
#1 Posted : 16 years ago
Eduardo 71
Hi there!
I have a whirpool dryer and wont start at all I checked the power and is fine 15 minutes later y can hear the timer working, but anything else isn't
#2 Posted : 16 years ago
A Model Number may help others help you.
Eduardo 71
#3 Posted : 16 years ago
Eduardo 71
I wrote yesterday abou t my dryer not working the model is LEQ9508LW0
AND ALSO I LIKE TO KNOW HOW TO USE THE OHMETER
Eduardo 71
#4 Posted : 16 years ago
Eduardo 71
I have a digital ohmmeter and would like to know where to set te dial if is the DC THE MA OR THE OMEGA SIGN, I cheked the belt and seems fine I don't have a manual and do not know wheres the thermosta, heating element or also how to chek any of these for continuity? THANKS FOR YOUR HELP
Eduardo 71
#5 Posted : 16 years ago
Eduardo 71
Originally Posted by: Eduardo 71 Go to Quoted Post
Hi there Denman I have a digital ohmmeter and would like to know where to set te dial if is the DC THE MA OR THE OMEGA SIGN, I cheked the belt and seems fine I don't have a manual and do not know wheres the thermosta, heating element or also how to chek any of these for continuity? The dryer won't star For what I've been reading I think the motor is shock and I think what I have is a mutimmeter
but I am not sure
#6 Posted : 16 years ago
Here is your parts breakdown
Replacement parts for WHIRLPOOL LEQ9508LW0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406661.pdf
Here is a good site with basic dryer repair help
http://www.applianceaid.com/dryers.html
The Omega sign should be ohms/resistance
Since the timer is running the door switch is probably OK.
The most likely culprit would be the THERMAL FUSE (196 degrees) in the motor circuit.It is the one mounted on the blower assembly (Item 7 in "Section 3")
If it is blown check that the blower is clean and OK.
Also clean/check your vent system.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest about a year ago
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 10 years ago
GE Electric Dryer won't start (Dryer Repair)
by brosnan 10 years ago
Electric dryer won't start (Dryer Repair)
by peterkirt 11 years ago
Kenmore 70 Series Electric Dryer Won't Start (Dryer Repair)
by rdtraverse 12 years ago
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 13 years ago
Kitchen Aid Electric Dryer Won't Start (Dryer Repair)
by ihtractor 13 years ago
by cakst35 13 years ago
trouble shooting electric dryer won't start (Dryer Repair)
by Domenic711 13 years ago
Maytag Electric Dryer Won't Start (Dryer Repair)
by Rosebud42 13 years ago
Electric Dryer won't start has power (Dryer Repair)
by coxc6419 14 years ago
Maytag neptune electric dryer won't start (Dryer Repair)
by area123 15 years ago
by fridayauction 15 years ago
by WhittierM 15 years ago
GE electric dryer won't start (Dryer Repair)
by aqrose 15 years ago
