Eduardo 71
#1 Posted : Tuesday, June 23, 2009 11:05:04 PM(UTC)
Eduardo 71
Hi there!
I have a whirpool dryer and wont start at all I checked the power and is fine 15 minutes later y can hear the timer working, but anything else isn't
#2 Posted : Wednesday, June 24, 2009 4:46:36 AM(UTC)
A Model Number may help others help you.
Eduardo 71
#3 Posted : Wednesday, June 24, 2009 12:57:39 PM(UTC)
Eduardo 71
I wrote yesterday abou t my dryer not working the model is LEQ9508LW0
AND ALSO I LIKE TO KNOW HOW TO USE THE OHMETER
Eduardo 71
#4 Posted : Wednesday, June 24, 2009 1:03:22 PM(UTC)
Eduardo 71
I have a digital ohmmeter and would like to know where to set te dial if is the DC THE MA OR THE OMEGA SIGN, I cheked the belt and seems fine I don't have a manual and do not know wheres the thermosta, heating element or also how to chek any of these for continuity? THANKS FOR YOUR HELP
Eduardo 71
#5 Posted : Wednesday, June 24, 2009 2:08:34 PM(UTC)
Eduardo 71
Originally Posted by: Eduardo 71 Go to Quoted Post
Hi there Denman I have a digital ohmmeter and would like to know where to set te dial if is the DC THE MA OR THE OMEGA SIGN, I cheked the belt and seems fine I don't have a manual and do not know wheres the thermosta, heating element or also how to chek any of these for continuity? The dryer won't star For what I've been reading I think the motor is shock and I think what I have is a mutimmeter
but I am not sure
#6 Posted : Wednesday, June 24, 2009 5:14:56 PM(UTC)
Here is your parts breakdown
Replacement parts for WHIRLPOOL LEQ9508LW0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406661.pdf
Here is a good site with basic dryer repair help
http://www.applianceaid.com/dryers.html
The Omega sign should be ohms/resistance
Since the timer is running the door switch is probably OK.
The most likely culprit would be the THERMAL FUSE (196 degrees) in the motor circuit.It is the one mounted on the blower assembly (Item 7 in "Section 3")
If it is blown check that the blower is clean and OK.
Also clean/check your vent system.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 1/22/2015 9:10:42 AM(UTC)
GE Electric Dryer won't start (Dryer Repair)
by brosnan 12/13/2014 2:08:12 PM(UTC)
Electric dryer won't start (Dryer Repair)
by peterkirt 3/19/2014 3:55:54 AM(UTC)
Kenmore 70 Series Electric Dryer Won't Start (Dryer Repair)
by rdtraverse 12/26/2012 6:31:15 PM(UTC)
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 7/26/2012 11:10:56 AM(UTC)
Kitchen Aid Electric Dryer Won't Start (Dryer Repair)
by ihtractor 6/14/2012 8:55:11 PM(UTC)
by cakst35 4/16/2012 8:40:32 AM(UTC)
trouble shooting electric dryer won't start (Dryer Repair)
by Domenic711 2/7/2012 12:33:50 PM(UTC)
Maytag Electric Dryer Won't Start (Dryer Repair)
by Rosebud42 1/6/2012 2:50:38 PM(UTC)
Electric Dryer won't start has power (Dryer Repair)
by coxc6419 11/25/2010 7:12:40 PM(UTC)
Maytag neptune electric dryer won't start (Dryer Repair)
by area123 7/8/2010 11:22:10 AM(UTC)
by fridayauction 6/1/2010 7:57:14 AM(UTC)
by WhittierM 1/8/2010 1:29:33 PM(UTC)
GE electric dryer won't start (Dryer Repair)
by aqrose 11/29/2009 2:52:05 PM(UTC)
