jayandcarey
#1 Posted : Friday, December 28, 2007 12:32:18 PM(UTC)
jayandcarey
I used the microwave and it worked normally. Removed that food then placed more of the same in the unit and when I pressed start the word "door" appeared on the screen and it will not start. I have tried repeating it multiple times but not working. I have reset the power to it but still no help. I have someone scheduled to come out but it seems like it should be simple.
thanks, jay
#2 Posted : Friday, December 28, 2007 12:45:46 PM(UTC)
Hi Jay
Most likely the problem with your microwave is a bad door switch.
The model number you posted does not look like a valid model number.
Verify the model number and repost it, please.
JHOLT29
#3 Posted : Sunday, November 22, 2009 7:44:11 AM(UTC)
JHOLT29
I found this question via a Google search and it is exactly the problem we are having. Unfortunately no answer. This is an in-wall over-microwave combination unit. The only numbers on the inside front of the unit are:
Tag on left side: 8538 791 54001 and under it XNR0568951
Tag on right side: UL FILE NO. E150072SP and under that FCC ID: KAW38AVM726
I'm sure this is likely a door latch sensor of some type, but where is it located and how difficult is it to replace.
#4 Posted : Tuesday, November 24, 2009 6:45:44 PM(UTC)
If this is an over the range microwave then the name plate with the model number should be on the door frame. "XNR0568951" looks like a serial number. The model number should be somewhere around. Usually (if microwave made by Whirlpool) it starts with two or tree letters.
JHOLT29
#5 Posted : Tuesday, November 24, 2009 8:14:53 PM(UTC)
JHOLT29
Gene:
It is a microwave/oven in-the-wall combination. Whirlpool gold. The microwave door drops down (vs. opening on the side). Does that narrow is down? Thanks.
#6 Posted : Tuesday, November 24, 2009 8:17:50 PM(UTC)
If this is an oven/microwave combo then the name plate with the model number is on the Oven door frame.
JHOLT29
#7 Posted : Wednesday, November 25, 2009 10:58:29 AM(UTC)
JHOLT29
Whirlpool combination oven/microwave built-in unit.
Model # GMC275PDR07
When trying to start microwave, the electronic screen says "DOOR" and unit will not work. Oven still works fine.
I tried shutting down the power at the circuit breaker to see if it would re-set. No success.
Any other ideas?
Thanks!
dshiah
#8 Posted : Thursday, July 22, 2010 9:56:09 AM(UTC)
dshiah
Hello JHOLT29,
I googled your posted problem regarding displaying "DOOR" error on your microwave. I recently got exactly same problem and wonder how you got it fixed? Can you please advise!
Thank you!
Daniel
StorageGuy
#9 Posted : Sunday, December 23, 2012 8:43:16 PM(UTC)
StorageGuy
Exact same issue and model! Any response on a fix?
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
whirlpool doorlock (Washer Repair)
by stevesxm 5/30/2012 12:10:34 PM(UTC)
Whirlpool Door Hinge (Washer Repair)
by TAKAUFF 12/21/2011 2:51:26 PM(UTC)
Whirlpool Door Leaks (Dishwasher Repair)
by farmall130 1/4/2011 12:56:17 PM(UTC)
Whirlpool Door Lock Error (Washer Repair)
by lambchops 3/30/2010 10:06:18 AM(UTC)
Whirlpool Door leaking (Dishwasher Repair)
by rrodgers12@woh.rr.com 11/14/2009 6:02:51 AM(UTC)
whirlpool door won't latch (Washer Repair)
by ESTELLA 7/16/2009 12:34:43 PM(UTC)
Whirlpool Door handle fell off..... (Oven Repair (including Ranges and Cooktops))
by FDAR 4/14/2009 12:20:32 PM(UTC)
Will Whirlpool door parts fit my Kenmore? (Dishwasher Repair)
by shacky 12/13/2008 12:24:45 PM(UTC)
Whirlpool Door Latch (Microwave Repair)
by crommy 3/15/2008 10:50:01 AM(UTC)
