The door leaks on this unit. The gasket looks OK, the water appears to come out from the center bottom. Could the gasket be bad or is it maybe a drain problem? It works fine, just leaks like a sieve! Doesn't appear to have any kind of seal across the bottom, only the sides. Thanks!
[COLOR="Blue"]Could the gasket be bad or is it maybe a drain problem?[/COLOR] The gasket sounds OK. If the unit is emptying OK then I doubt it would be a drain problem. Let it fill and then after the first drain and refill check that the fill level is the same as the first fill.
Check the holes etc on the spray arms. Sometimes a hole can partially plug and then the water sprays out at a weird angle causing a leak.
Check the seals on the vent and dispenser. May be one of them is leaking and the water is running down the inside of the door and then dripping out at the bottom. |
THIS FORUM IS DEAD!!!!!!! |
