ginteal0
#1 Posted : Saturday, January 16, 2016 3:53:55 PM(UTC)
ginteal0
Began with not fully spinning/draining on final spin. Would respin/drain and seemed okay. After several loads like this the next load did not respin/drain when set to this and left water laying in washer. Tried next to start a cycle to watch exactly what was happening and it will now not even start a cycle. Lights come on, door lock light is on and door will not open but it will not even begin to fill.
ginteal0
#2 Posted : Sunday, January 17, 2016 2:57:30 AM(UTC)
ginteal0
Does this sound like it is the control board?
sidfink43
#3 Posted : Sunday, January 17, 2016 5:49:55 AM(UTC)
sidfink43
Not sure, the door lock assembly can also cause these symptoms.
Inside the lower service panel are tech notes that will tell you how to put it into diagnostic model and generate error codes and test some components. Focus on the door lock assembly and speed control board. But these models are hard to diagnose and in the end you may just have to start replacing parts and see what fixes it. If you buy the parts from this site you can return them if they are not needed.
ronaldschenk
#4 Posted : Monday, January 18, 2016 12:18:57 PM(UTC)
ronaldschenk
I also has a similar problem and the door switch assembly fixed the problem. There is more than one circuit the door switch is handling.
Frigidaire fgus2642lf2 auger not getting power (Refrigerator & Freezer Repair)
by knmens 4/15/2024 6:17:43 PM(UTC)
Frigidaire Evaporator Fan (Refrigerator & Freezer Repair)
by KevN1974 4/13/2024 11:03:34 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Frigidaire Front Load Dryer aeq6000es2 (Dryer Repair)
by Guest 3/3/2024 7:28:15 AM(UTC)
Frigidaire FGHS2655PF5A Gallery side by side (Refrigerator & Freezer Repair)
by Rube 2/27/2024 7:56:33 PM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Frigidaire oven diagram control board (Oven Repair (including Ranges and Cooktops))
by Guest 1/22/2024 10:28:10 AM(UTC)
Frigidaire Freezer Handle (Refrigerator & Freezer Repair)
by Guest 1/21/2024 12:46:23 PM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Frigidaire FSG747GES0 dryer motor (P/N 131461900) growls on start (Dryer Repair)
by RJ539 1/12/2024 9:00:21 AM(UTC)
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
