Guest
#1 Posted : Sunday, March 3, 2024 7:28:15 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Hello,
I have a Frigidaire Dryer, aeq6000es2 that developed a consistent squeaking sound. Did some reading and ended up changing the rear bearing and belt. Now I am experiencing a different sound that is intermittent. It is more of a rubbing squeak than before. Any idea what I should look at next?
Guest
#2 Posted : Sunday, March 3, 2024 7:47:18 AM(UTC)
Guest
Rank: Guest
Groups:
United States
I am not real familar with this model but there are 2 things you should look at as a cause of this noise. The first would be the front drum support which is typically on this design a plastic ring at the front cover that is worn badly. The other possible source would be the belt idler pulley . It is possibly worn badly at the bore where it slides/rotates
bronn033
#3 Posted : Sunday, March 3, 2024 11:43:34 AM(UTC)
bronn033
United States
Thanks for the reply. It's weird because the sound isn't constant, but is definitely rhythmic. It also only happens for about the first 5 minutes of the cycle.
