Good Morning I would like to find out what it is that allows my cloths washer to start to fill but never shut off water continues to drain and overflows in the vent pipe. All is clear pulled off all hoses and checked for blockage none found. I feel its the Washer Water Level Switch but don't know what is allowing water to flow out. Is there a valve that should be after the tub that is stuck open. Thanks
