djjd
#1 Posted : Sunday, February 8, 2009 7:15:05 PM(UTC)
djjd
Hello! I have a Whirlpool LTE5243DQ thin twin stackable washer/dryer. The washer is making a very loud rubbing or grating sound during agitation. The sound is not present during spin. Any ideas for replacement parts I could try to fix the problem? Many thanks.
#2 Posted : Monday, February 9, 2009 2:51:16 AM(UTC)
You might have busted agitator paws in the upper section of the agitator. Just verify by turning the upper section. If bad, remove the 7/16 nut and pull out the agitator. Stand on the lower section of the agitator and yank off the top section.
djjd
#3 Posted : Monday, February 9, 2009 9:33:21 AM(UTC)
djjd
Thanks for the reply. I don't get any noise from manually moving the agitator and the paws that engage the removable portion seem to be in good shape. The sound is like a sawing that goes with the action of the agitator. What should I do next to troubleshoot?
#4 Posted : Tuesday, February 10, 2009 12:29:49 AM(UTC)
Pull out the agitator and check it, might have something stuck in there.
djjd
#5 Posted : Thursday, February 12, 2009 7:47:08 PM(UTC)
djjd
Rich thanks for the continued advice. I pulled the agitator completely and ran the agitation cycle of the wash. The sound is still present. It sounds like a power drill on/off coming from inside the cabinet. I don't know how to get in there to look (and listen) around. Any advice?
#6 Posted : Friday, February 13, 2009 12:26:09 AM(UTC)
Remove the screws from the panel above the washer door and remove each riply spring clip. Lower washer outer panel will slide right out. Washer should agitate without the lid switch.
djjd
#7 Posted : Monday, February 16, 2009 8:14:51 PM(UTC)
djjd
Rich, thanks for all your help. I would not have made it this far without it. It looks like I have a broken spring in the rear left hand corner which tilts the tub and causes the motor to come in contact with the washer base, and thus noise!
So, I see the springs for sale on the website. Do I need to pull the tub to do the replacement or can I swap out the springs in place? If I need to pull the tub, is the only tool I need the spanner wrench?
Thanks!
djjd attached the following image(s):
#8 Posted : Tuesday, February 17, 2009 12:34:22 AM(UTC)
Looks like there is a screw under the bottom frame to take out, then brace the bottom of the transmission with wood to pull the spring out.
Let us know how you make out with this.
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
door open code Whirlpool WRX986SIHZ00 (Refrigerator & Freezer Repair)
by Guest 4/20/2024 5:54:26 AM(UTC)
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
How does Whirlpool agitate? (Washer Repair)
by Alex Pabloroux 4/12/2024 1:40:40 PM(UTC)
Whirlpool WRS325FDAM04 (Refrigerator & Freezer Repair)
by nhred71 4/11/2024 10:32:03 AM(UTC)
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
Whirlpool WFW5620HW3 F6E3 Error (Washer Repair)
by hunt_ak 3/25/2024 12:55:01 PM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 3/18/2024 12:17:23 PM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
