My first problem was start relay on compressor. Replaced and working. Next the evap fan running intermittently, like trying to start every 3 seconds, then run a while, then start over. All of this weather compressor is running or not.
Then frige started getting warm but freezer OK.
Pulled freezer panel off to find evaporator iced over.at this time the evap fan was running constantly, so could it still be the fan?
I defrosted with hair dryer, restarted and all worked fine, till it got up to temp, then started doing same thing. Evap fan starting every 3 seconds and so on. Frige is holding around 50, probably due to lack of air flow. I haven't noticed and frost build up in freezer as of yet. its been a few days since I defrosted.
