jsstabby
#1 Posted : Monday, March 31, 2014 9:54:52 AM(UTC)
jsstabby
Our fridge doesn't cool. Compressor and condensor cooling fan are running OK. Evap fan won't run and fridge beeps every four seconds. Beeping stops when I disconnect evap fan motor. I have 12 volts to fan motor, checked when I unhook fan motor. Bi-metal and heating element have continuity. Replaced evap fan motor with new - get the same beeps and fan won't run. Next guess is, I have to have the control board rebuilt (W10219463). Core Centric Solutions says they can do it. I cannot find the control board! Everything says it is just to the left of the compressor, but all I find is the inverter. Do you have a picture or a video that shows the location of this control board? I cannot find it to remove it!
#2 Posted : Tuesday, April 1, 2014 4:15:08 AM(UTC)
It's behind the control panel in the fridg section.
jsstabby
#3 Posted : Tuesday, April 1, 2014 7:19:19 AM(UTC)
jsstabby
Are you talking about the temperature control board? It is in the drop down control box. I am looking for the power control board that is supposed to be under the fridge liner, but I do not see anything that looks like a control case - just the inverter. Thanks for your response.
#4 Posted : Tuesday, April 1, 2014 7:41:30 AM(UTC)
Look at the break0own diagrams, I only see a big control board.
jsstabby
#5 Posted : Wednesday, April 2, 2014 5:55:56 AM(UTC)
jsstabby
I found it. An article on ************************.com
Defrost, Condenser, Temperature, or Other Problems in KSS, KSC and other Whirlpool/KitchenAid/Kenmore/JennAir/Maytag Refrigerators « ApplianceBoards
Claims that this particular board (verified it is identical to mine) should have 11.5V or higher between pins 9 and 11 and the board is good. I have 11.68VDC, so my board should be good. I am also getting 11.68VDC to the fan motor. I replaced the evap fan motor, and my problem still exists. What else could be the problem? What are the chances the motor you sent me was also bad?
#6 Posted : Wednesday, April 2, 2014 7:21:32 AM(UTC)
Your board must put a square wave out to run the motor, you have a bad board. Make sure the motor is new also.
jsstabby
#7 Posted : Wednesday, April 2, 2014 7:35:46 AM(UTC)
jsstabby
Sorry to be a bother, but one last thing. I have seen on a website that a new jumper harness is supposed to be installed when replacing the evap fan motor. Could this be the issue? If not, I will have my board rebuilt.
Evaporator Fan Installation Kit For KSS, KSC, and other Whirlpool/KitchenAid/Kenmore/JennAir/Maytag Refrigerators « ApplianceBoards
#8 Posted : Wednesday, April 2, 2014 8:05:27 AM(UTC)
I know nothing about this .
